High Resolution Audio
Dec 19, 2014
I am becoming more and more interested in hi res music so i got the Sony BDV-E3100 and LG 32" Smart TV and i am so happy with the sound and the picture but i want to believe that i am not enjoying music the way i want, even though i have less experience with systems, so i wanted to buy a separate system for music and on low budget.
I have Denon DM39 in mind but i have plenty of flac audio files on my external hard drive or i can transfer them to a 32GB flash drive but is like the Denon cannot handle flac and the Sony doesn't have Optical out (i don't like using analog connection).
1- is there any Micro system that can handle flac but within range of the Denon? 2-Do you think the BluRay home theater can play music better than the Denon DM39 since it can handle flac? or 3-Should i just replace the Sony with something better with music and movies but my budget is not more than $400. Thanks
I'd look into getting an av receiver with a pair of decent budget stereo speakers - sub optional.
The DM39 is ok but you'll get more flexibility from a modern receiver with your smart equ - and yes imo your blu-ray into the receiver will perform better than the DM39 - plus have the option of future upgrades with built in features unavailable from the DM39.
We have a DM38 in the house. It is what it is a midi system.
