shadders said:
				steve_1979 said:
				shadders said:
			It is an opinion - you have stated :
It's a fact that 16/44.1 can sound identical to 24/96. This has been proven many times (including in this thread by fr0g).
This thread has not proved it, and you used the word can - which is not absolute.
16.44.1
can sound different to 24/96. But if a 24/96 file is converted into 16/44.1 using any compentent software that does the job properly then it
will sound identical.
As I said to lemon: "The differences between 16/44.1 and 24/96 are less than -80dB down in volume or occur at ultrasonic frequencies over 20kHz." Unless you can hear noise that is less than -80dB below the music volume or can hear ultrasonic frequencies they
do sound the same.
				shadders said:
			I asked fr0g whether he believed that cables sound different or not.
Cables
can sound different.
But all cables that meet the necessary specification
do sound identical.
p.s. If anyone wants to discuss whether cables sound the same or not I respectfully ask that you start a new thread rather than take this one of topic.
The point is that if a person states that difference sounds below -65dB cannot be heard, and cables difference are below this threshold, the cables do not sound different. My analysis shows this based on fr0g statement that differences below -65dB cannot be heard.
As such, you cannot state that differences below -65dB cannot be heard, i provide analysis that two cables have a difference below this threshold, and then state that cables do indeed sound different.
fr0g has not detailed his process - hence the process, analysis and results cannot be investigated.
Performing a test and only sharing some of the process and results is insufficient to believe the results and conclusions.
The fact that fr0g cannot hear the difference means just that - fr0g cannot hear the difference - there are many other people who may be able to hear the difference.
Regads,
Shadders
I don't think I said that about -65 dB. (I do think it is still the case, but I didn't say it).
I mentioned 65 dB in a purely hyperthetical  example as to the difference between the volume of a "silent" room at 25 dB and a "loud" listening volume at 90 dB
As for the cable question, very off-topic, but I don't mind answering.
I am not sure.
There is definitely a difference if you swap a cable that is too thin or resistive, for one that isn't.
I "think" I have heard differences, albeit subtle, between analogue cables...but I doubt I could ABX them. Moving your head 1cm makes more of a difference to the sound. My opinion is that any reasonably built multistrand copper cable will sound identical to most people. I have a selection of interconnects from before I actually tested myself, nothing too expensive, but between £5 and £100 per metre. They sound the same. So much so I will happily use the freebie black cables that come with some kit. It is the equal of the £100  a metre stuff. And I would literally bet my house that nobody could prove me wrong in a blind test.
Digital cables, within spec, sound identical, or rather, they don't have a sound, they transfer digital data. Audiophile USB, HDMI,optical, CAT5+ etc are without doubt a complete con.
