altruistic.lemon said:jcbrum said:p.s. Just in case any readers don't know what DSD is, the following note might be of assistance . . .
DSD is 1-bit, has a sampling rate of 2.8224 Mhz. The output from a DSD recorder alternates between levels representing 'on' and 'off' states, and is a binary signal (called a bitstream). The long-term average of this signal is proportional to the original signal. DSD makes use of noise shaping techniques in order to push quantisation noise up to inaudible ultrasonic frequencies. In principle, the retention of the bitstream in DSD allows the SACD player to use a basic (one bit) DAC design which incorporates a low-order analog filter. The SACD format is capable of delivering a dynamic range of 120 dB from 20 Hz to 20 kHz and an extended frequency response up to 100 kHz, although most currently available players list an upper limit of 80–90 kHz and 20 kHz is the upper limit of human hearing.
JC
You seem a nice bloke, jcb, but only when you're not in patronising mode![]()
I'm glad you are not being entirely serious or I'd suspect you of making a virtue out of ignorance or do you just feel left out?. If JC had used a sneering manner or had been overtly superior, I might agree. I now have a far better idea of how digital audio works from such posts, the links & my willingness to read up. Understanding technical stuff does take effort & one's own bafflement can be frustrating but I still have a passion for learning as well as for music.
