gel:daveh75:
gel:
I have been looking at this stand recently and it measures in 40cm wide, my amp is 44cm wide, so what good is that then?
I thought this was suppose to be one the main av racks, i can't seem to find it in different widths, anyone know if it can be done wider?
Think you're getting confused here, the Podium XL stand is 400mm deep, but 800mm, 995mm or 1200mm wide,
http://www.hifiracks.co.uk/userimages/procart38.htm
But hifiracks also offer a bespoke service, so can build rackss to your design/size requirements.
Yep that is the stand at 400mm deep, do you know how much it will cost to go to around 500mm deep, this stand is already expensive, i have emailed some people just waiting for a response, you would think that it would be standard around 500mm deep, not so that you can't even get your amp on.
I can't remember the depth of mine - I got it before they named it the Podium. However, my receiver and stereo amp fit nicely.
www.flickr.com/photos/50367271@N04/5284321536/
