There is a lot of misinformation in our hobby and it's not quite as one way as it might seem.
For example, are following 3 statements fact, fiction or conjecture?
1) All amplifiers sound the same.
2) Tube amps are popular because they distort the sound in a pleasant manner.
3) All cables sound the same.
None of those statements are facts. 1 & 3 are straight up fiction and 2 is conjecture. It's easy to either completely misinterpret the results of DBT(double blind testing) and measurements or to draw conclusions that aren't actually proven.
The facts are that in DBT, no one has been able to prove that level matched amps, that measure the same, sound different. That is is a very different proposition from "all amps sound the same". It tells you that under certain conditions amps may sound different. First, if they're not level matched; even a relatively small increase in volume can make one amp sound better than the other. Secondly if the amps measure differently. So don't make the assumption that you can randomly pick the cheapest amp off the shelf and it will sound the same as the $15K one in the HiFi store. Just look at reviews that actually measure products and you might be surprised at how differently some products measure. Note that many expensive products measure terribly, so price is not a great indicator of quality/competent design.
Likewise, tube amps tend to measure poorly compared to solid state amps, but that doesn't prove that the only difference between the two is distortion. To provide compelling (though not absolute) proof of that, someone would need to design SS amps to directly mimic the distortion of various tube amps and then do DBT to see if the tube fans can tell the differences. This would be similar to the Carver Test (but a lot more rigorous).
Cables are similar to amps. They have to meet basic specifications to be "expected" to sound the same. For example, running 50 feet of 18 gauge speaker wire for a 4 ohm load probably isn't the best idea.
What all this means, is that when someone claims they heard a difference between amps or even speaker cables, you can't just assume that it was all in their imagination, as there may well be measurable reasons for the differences.
