Heybrook point 5 speakers
RichHL
8
need some advice on choosing a suitable amp for these speakers.
6 ohm, 70 W, 89db.
not looking for high end as sadly would be beyond my budget.
Definitely needs a phono input for my Thorens and Bluetooth would be great.
up for any suggestions - even an all-in- one, if there is such.
Many thanks for looking, and for your responses.
6 ohm, 70 W, 89db.
budget?
Bluetooth can be added via an adapter if necessary, best concentrate on the quality of the phono input.
Reactions: RichHL
If you can stretch to £325 there’s a nearly new Rega io amp on eBay. Otherwise something like the recently superseded Marantz 6006 can be found for around £300.
Brand new, something like a Cambridge AXA35 has a phono stage and cost £299. I’ve not heard one, but Richer Sounds can demonstrate one for you.
Many thanks! Very grateful for your response. I’ll look into these. Here’s hoping!
You’re very welcome, Rich. I should have said the Marantz is the PM6006.
Failing all of those, Richers also have two Yamaha receivers within budget with Bluetooth, but neither has a phono stage. That would add another box and, say, £70 to the cost.
