- Aug 25, 2014
- 2
- 0
- 0
guys new user here
i'm after some help setting up a wharfedale diamond sw150 subwoofer with a set of 5 boston acoustics soundware xs sateliite speakers.
the frequency response of the sw150 is 35Hz to 110Hz and the controls i can change on the sub are as follows
phase adjustment: 0º or 180º
crossover frequency: 35–85Hz (10Hz steps)
the specs of the boston satellites that i think are relevant are
crossover freq: 5kHz
freg response: 150Hz – 20kHz
impedence: 8 ohms
sensitivity: 85dB
the only thing i am fairly confident at setting is the volume control on the sub . i set this at 12 o'clock position. everything else on the sub i am just not sure what to set. the speakers and sub are connected to a yamaha RX-V673 receiver. the yamaha manual suggests setting the crossover on the sub to its maximum (85Hz)?
once i have the settings on the sw150 figured out, i can run the ypao auto setup feature on the yamaha. any help would be greatly appreciated
impedence: 8 ohms
sensitivity: 85dB
