I'm choosing between the Onkyo TX-NR808 and the TX-nr5008, whichever 1 i buy will be swapping out a Linn Kolektor pre-amp so my current music only setup can start being used as a home theatre system.
Which of these receivers is the closest comparison to the Kolektor? The Kolektor is a few years old now, so would the materials in the 808 provide a similar sound to what I'm used to or do I need to step up to the 5008?
Budgets not really an issue, though if I can spend less I will...
2 x LK140's, bi-amped and bi-wired to 2 Castle Howard S1s.
Linn Kolektor, pre-amp.
Linn Karik CD player.
Linn Numerik DAC.
Will be adding either B&W 684 theatre or Monitor Audio RX6 Silvers AV12
Linn Numerik DAC.
