tino
Don't these look nice ... http://www.gamutaudio.com/en-GB/Products/Accessories-and-Upgrades/Stand-for-L3.aspx.
No builders merchant ironwork here.
BIGBERNARDBRESSLAW said:Hi, My name is Stu Whisson, I have no idea how to design a perfect pair of speaker stands, but if you design them for me, I promise to make lots of money for myself and my company.
Give me a break.
Dr Lodge said:I always liked the ESPOS ES14 stands I have...custom made for the speaker so they fit perfectly, spikes on top as well as under neath, look quite nice (no big scaffolding tubes).
May be your perfect stands need to be adjustable in size then...
tino said:Has the OP gone AWOL? Thought you wanted some interactive discussion? oke:
PhilBlvdElec said:My two cents on stands : why the hell do they cost so much? It's not as if the principle needed to be fully designed over two years by a team of 25 highly paid specialists. Only the material used defines the cost, for all I care, so if one wants real wood or marble, then he should be prepared to pay a certain price. But metal? Cement? I don't know what other cheap material? Come on, using the price point for stands made out of metal, every nation in this world would be totally ruined after having built it's second skyscraper. You can shape the damn thing the way you want, you can put six spikes instead of four, or use an open top, or just make a simple post well grounded and looking nice, but the goal will always be to get heavy materials that do not transmit vibrations, and to put it on a decent contact point - or many as is common. One guy with a little brains in the matter should be able to sit on a chair for 5 hours a day during a whole week, and design something that works and doesn't look bad. And it should not cost more than £100 when the materials are as such mentionned above. It is a SIMPLE STRUCTURE that can easily be made TO LOOK NICE. What the hell, paying £300 for decent stand-mounted speakers, and another £250 for the ******* stands to put them on?! THEY ARE STANDS, not exactly Hi-Fi separates requiring advanced engineering, microscopic precision, and tons of calculations and calibrations to try and find an equilibrium between everything...
Now let's look at something... the universal stand. Yes, it does exist. If, say, Monitor Audio BX6 costs £550, and are provided with plates on which to put the speakers, and spikes to adapt it to a surface, then I fairly assume that the said plates don't justify 60% of that price. In fact, I can fairly assume that similar plates could be provided with stand-mounted too. Speakers would also be designed to still be small, yet made to sit in such a plate. The plate, of course, would be discreet and nice looking, like many companies already do them for floorstanders. Or perhaps someone cleverer than me in those matters - because I really am the dumbest person when it comes to engineering something - could think of an even better solution. Whatever... Then exit the small spikes used for floorstanders, and enter a single bolt-on universal structure made something like a small, thin funnel - the plate can be screwed solidly onto something - thick and heavy metal bolt - while the funnel shape allows it to enter into the top of any stand and look nice and unified. The whole made to encounter the contact point quality of already existing floorstanders plates - which, I still assume, seems to please pretty much everybody, unless they have a very uneven floor. Then, all what's left to do is to produce stands that can be fitted with that universal shape... and produce said stands in whatever shape and design you might think of. ray:
Come on... don't tell me nobody came up with that before... And I'm stupid in those matters, I can only repeat it, and surely there is something illogical somewhere in my design... but I'm quite sure it can work between the hands of - say - my brother. And if he can, then anybody with similar skills does. Then WHAT the HELL is the problem with stands? :shifty:
Cpt.Issues said:Talking of over Engineering..
"One of the biggest issues with any system is isolation of the speaker from the rest of the room. "
Thinking outside the box, isn't this effectively what shock absorbers do on a car? To an extent they isolate the car from bumps in the road by smoothing out shocks (vibration) from the road surface?
Continuing this theme; has such a concept as 'floating' stands ever been developed? Perhaps not fluid filled obviously but incorporating some sort of dampening medium between the speakers and floor aisde from current gel pads etc?
CnoEvil said:Cpt.Issues said:Talking of over Engineering..
This crowd do a good job, but they are VERY expensive (and very effective): http://www.trackaudio.co.uk/[/quote]
Wow, CnoEvil, thats a piece of engineering . . . takes 'over engineering' to a new level . . . as an engineer it gets 11/10 . . . ? I dare not look at the price tag . . . but, boil it down to; 'how does it sound' ????
Max Townsend does a sprung/floating speaker/stand combination . . . but the price, I seem to remember a figure of £70,000? being mentioned?
Part of the theory is to hold the speaker still, air has a surprising mass, on which the cone pushes and moves the said pushed air, if the cabinet can move in the opposite direction to the cones pushing force, it will compromise the sound . . . ?
CJSF
CnoEvil said:This crowd do a good job, but they are VERY expensive (and very effective): http://www.trackaudio.co.uk/
CJSF said:Wow, CnoEvil, thats a piece of engineering . . . takes 'over engineering' to a new level . . . as an engineer it gets 11/10 . . . ? I dare not look at the price tag . . . but, boil it down to; 'how does it sound' ????
CJSF
chebby said:CnoEvil said:This crowd do a good job, but they are VERY expensive (and very effective): http://www.trackaudio.co.uk/
And resemble tubes made from lots of short vacuum cleaner hose extensions.
Give me a break.
CnoEvil said:CJSF said:Wow, CnoEvil, thats a piece of engineering . . . takes 'over engineering' to a new level . . . as an engineer it gets 11/10 . . . ? I dare not look at the price tag . . . but, boil it down to; 'how does it sound' ????
CJSF
The Track Audio stuff works, where little else will....though the 600mm cost £1300 The Townsend Stello Stands cost about £1000 (positively good value!): http://www.townshendaudio.com/hi-fi-vibration-isolation/stella-stand[/quote]
Still a lot for 4 springs/4 feet and a couple of fancy plates, very questionable operation theory IMHO? Got the feeling the 70K might have been including his concrete speakers??? . . . ho hum, viva la Max!!!
As I say, I like the engineering of Audio Track, I can even see why the stand might work in certain situations . . .? However, £1300.00 . . . OK, simply justified by A-B addition, if it works pay the money . . . after all the customer would not be there in the first place if £1300 was an issue. We used to always advocate an A-B test on all our stands, just occasionally they did not match 1 in 10 for the Classics, 1 in 5 for the more complex Pi and Designer . . . the positive A-B's were usually mind blowing, ask Ken Kessler.
I have to admit, my 'Designer stands' would be pushing £1000 these days and 'Pi' £600 . . .
A problem in the quality end of the hifi industry that is not considered is the low volume production, always make things expensive.
CJSF
CJSF said:Still a lot for 4 springs/4 feet and a couple of fancy plates, very questionable operation theory IMHO? Got the feeling the 70K might have been including his concrete speakers??? . . . ho hum, viva la Max!!!
CJSF
CnoEvil said:CJSF said:Still a lot for 4 springs/4 feet and a couple of fancy plates, very questionable operation theory IMHO? Got the feeling the 70K might have been including his concrete speakers??? . . . ho hum, viva la Max!!!
CJSF
I have a friend whose system is in his bedroom, which is in the roof space of the house. Speakers never sounded right until he used this solution, which is very effective at isolating them from the floor. In my case, I use Auralex Grammas, resting on Granite worktop savers and trimmed with wood...£110 all in!
CJSF said:Ah . . . wood floor isolation . . . what a bind.
CJSF
CJSF said:Best speaker stand ever made . . . I dont think there is, or will be any such thing, to many variables?
CJSF
