Advised info from the Miller Kreisel subwoofer operations manual.
6. If you have a Dolby Digital AC-3 5.1 channel processor/receiver, follow these instructions.
SPECIAL NOTE: Always check the processor/receiver's owner's manual. Different manufacturers use
different descriptions for the same function, and sometimes the same description for different functions!. Your
component may use terminology different from that used below.
A. High-Pass Filters: All Dolby Digital processor/receivers have built-in high-pass filters for the Left,
Center, Right, Left Surround, and Right Surround channels. Always turn these filters ON by
using the SMALL setting. If you have a THX component, use the THX setting. See the owner's
manual of the processor/receiver for instructions.
B. Bass Management: If the processor/receiver has a setting to turn the Subwoofer off or on, make
sure that it is set to SUBWOOFER YES or ON.
C. Dialog Normalization: If your component has this function, turn it off to avoid any possible effect
on sound quality.
on sound quality.
