help needed to choose speakers to fill big room
koswo
I need some advice about speakers. I have a NAD C 352 amplifier (2 x 80W Continuous Power into 4 / 8 ohms). The problem is that our living room has a high ceiling and so with the current speakers the sound kind of "vanishes". Admitted: currently I use a pair of very old and crappy Sanyo speakers (continuous power: 35W, max power: 50W, impedance: 8 ohm) ;-)
Now I would like to buy a pair of good and affordable (max 2500 EURO) speakers that I can use with my current NAD amplifier, that are powerfull enough to fill up that "big" living room and that don't look too bombastic.
Can you guys help me?
Thanks a lot!
Koen
audioaffair
100
Hi Koswo,
We have just unboxed a pair of these superb Focal speakers, which may be worth looking at, these are a very substantial speakers, for a large room:
http://www.audioaffair.co.uk/focal-aria-936-speakers-pair
Alternatively, something like the Dali Mentor 6's may also fit the bill, another great speaker to check out.
koswo
First of all, thanks for the feedback so far!
@Sir Lemon : What do you mean by "horns"? Do you have any examples? Line arrays will be a bit bombastic and expensive I guess...
@NHL : What type of Klipsch for example?
@audioaffair : Usually I listen to rock music, which ones are better for that purpose? The Dali's or the Focal Aria's?
Thanks!
Sir Lemon
By horns I mean horn loaded speakers, in particular front loaded horns. They tend to project the sound further in front of them and land a bigger sound stage than your tipical boxes (of course, there are exceptions here, but the rule stands).
In regard to the examples your asked for, there are too many to list, Klipsch makes horn speakers of this flavor (as suggested above), so does JBL, Odeon (Orfeo and Fidelio would fit your budget) and many, many others.
lindsayt
16
A few horn examples:
Avantgarde
Cessaro
EV - 1950's to 1970's model line-ups
JBL - 44xx plus other model ranges
Altec Model 19's, VoTT's, Valencias etc
Urei
Vitavox
Klangfilm
Living Voice
Sansui - early 1970's product range
Klipsch - Klipschorns, Scala, Belles, Jubilees, Cornwalls, Heresy
my room measures 13ftx18ft which is a decent size i suppose.
i would definitely recommend giving the focals a listen to.
they are very detailed and punchy. bass is tight, powerfull, but not overblown. mids and trebles are detailed and strong.
the speakers look fantastic too, which is a strong point for me also.
davedotco
My initial reaction is that spending that much money on speakers for what is still a (fairly high powered) budget amplifier is not ideal.
Until I saw your proposed budget, I was going to suggest the Q Acoustics 2050i. Nice and sensitive at 92-93 dB/w and if you give them space they can work very nicely. If you want significantly better it becomes less easy.
There are some inexpensive (new) horns but the better designs tend to be quite pricey and second hand could be fraught with danger unless you are able to take Lindsayt with you to advise.
I would talk to a few dealers who specialise in valve amplifiers, they usually have a decent knowledge of more sensitive speakers.
Edit to add. The Focals mentioned above are reasonably sensitive, Focal speakers are not, generally to my taste, but they should work id you like the sound.
koswo
Hi davedotco, I don't necessarily need to spend that money. Only thing that matters (besides of course decent sound quality) is that the speakers are powerful enough to fill my room. Maybe I have to add that the room measures 5 x 8.5 meters (which is about 16 x 27 foot) with high ceiling!
So if you think that the Q Acoustics can manage this, even if they're below budget, it's OK for me :)
You mean the 936 or the 826v ?
koswo
I've been reading some reviews and I'm considering the Q Acoustics 2050i. What cables to you guys advice to connect those to my amplifier?
