Help! Connecting A Sub Woofer To An Amp
I need help please people.
I have just bought the SONY STR-DG820 amp and I am trying to connect it to the sub woofer that I already have. The sub woofer is from the all in one speaker system that I bought a few years back (I know it's old) - the SONY DAV-S550.
The problem is that the amp has an RCA output to the sub, whereas the sub has the input connection that is a speaker cable (2 wires). Is there such a cable that I can buy (RCA to speaker cable)? If there is no such cable, is it possible to modify an RCA cable and use it?
If I haven't explained it well enough, here is where you can find the two product manuals:
http://support.sony-europe.com/manuals/manuals.aspx?site=odw_en_GB
If anyone could help me I will buy them a pint!!!!!
Ain't gonna work! The receiver outputs a preamp level signal, and needs a power amp built into the subwoofer (ie an active subwoofer) whereas that sub you have is a passive one, driven by an amp in the 'head unit' of your old system.
You need to buy an active subwoofer.
Many thanks. As well as buying you a pint, I now think that I'll have to buy some new style speakers.
I plan on spending about £250 and buying the JAMO A102HCS5 that you guys reviewed and gave 5 starts. Are there any other syle speaker packages you would recommend for that price or under?
spike_the_biologist:Are there any other syle speaker packages you would recommend for that price or under?
Not much, I'm afraid. Although last time I looked Richer Sounds was doing the original KEF KHT1005 system for just under £200, which is a bit interesting.
Many thanks for your help and swift response - much appreciated.
