Help buying Amplifier
juliz7
Hello guys!
How are you?
I am trying to buy a new amplifier to connect with my Rega Planar 2 and my Chario Constellation speakers. At the moment i have a Marantz 5004, and i would like to change it for something way better!
I was checking the Marantz PM7000N as one of the options to buy.
Could you recommend me some brands and models around the same price and similar features?
Thank you!
JohnK
Have you considered sticking with the Rega theme and looking at the Rega Elex-R? It would appear to be in the same price bracket as the Marantz. It should compliment the Rega turntable and has excellent reviews. Just a thought. JK
Reactions: emcc_3
rainsoothe
185
69
18,670
You could look for a second hand Naim Unitiqute 2, you'll just need an external phono pre (Schiit Mani or one of the Rega/Pro-ject offerings should suffice). I think you can get both within your budget.
insider9
725
287
5,270
Nice suggestion guys. OP you're basically saying..
. I don't really like my amp so I'll buy something I don't like just for more money........ 😂
Also always fancied some Chario speakers. Italians just know what they're doing.
ASK THE COMMUNITY
