Chario (passive) vs Edifier (active) vs Sonus Faber (active)
mike1986
30
7
45
Hey folks, I need to ask for your advice, suggestions, and ideas 🙂 I'd like to take my home audio setup to the next level and replace my current Edifier S3000Pro + Audiolab 6000N Play setup with something with a wider soundstage, deeper and faster bass, and better instrument separation. I basically have three setups that always have to include Tidal streaming. My budget is $4,000.
1. Sonus Faber Duetto as active speakers, without any extras, because they already have everything I need, including Tidal streaming. Cost is around $4,000.
2. Airpulse A300 Pro + Bluesound Node Icon. Cost is around $3,000.
3. Chario Constellation DELPHINUS MKII + one of the amplifiers below (though most are out of my budget).
- NAD M10 v3 - my favorite in this set
- NAD C 700 v2
- Cambridge Audio Evo 150SE
- Marantz Model 40n
The room is approximately 35m² and I have no space for floorstanding speakers. Which of these systems makes the most sense? And why?
Thanks in advance!
I love Sonus faber but the powered wireless Duetto don’t seem to have inspired any particularly passionate reviews. And the used ones I’ve seen are heftily discounted, which makes me wary.
The only ‘system’ I’ve heard that approximates to your requirements is the Kef LS50 Wireless, which needs no external streamer or amp, and only needs your phone or tablet. Plus you can add an external device like a CD player should you wish to.
Can you hear any of these systems, because they are likely quite different in character and usability. If you like the KEFs, please budget for the matching stands.
Thanks for the opinion! I attribute the Duetto's lack of success to the fact that, at this price, any audio enthusiast will choose passive speakers for greater system control and the ability to experiment with different amplifiers.
I considered KEF, but I have the distinct impression that their sound is very muffled and heavy, with the low end overshadowing the entire treble. But that's just my impression based on listening to several YouTube videos with good headphones. I just don't understand their enormous success 🙂
Well I can tell you that’s not representative of the KEF at all. I owned the passive LS50s and they are very even handed. I’m sure some get paired with inadequate amps, but the actives obviously don’t have that issue. They also have a limited room EQ to adjust for placement. Funnily enough, I nearly said above that you might want a subwoofer, but I wanted to be succinct!
However, it’s impossible to gauge how speakers will sound in your home via YouTube and headphones, however well intentioned the presenter is.
Ok, so I will put them on my list and listen in some store, if available. However, I don't have a place for the extra subwoofer 😔
I like your choice of active speakers, you could match it with Eversolo Transport streamer T8 with the new Gustard R30 R2R then I saw the price, holly molly!
Mind you, the R30 is a streaming DAC, adding the T8 is a bit excessive, adding a DAC without the streaming probably best, such as the Denafrips venus ii or if this exceeds your budget downscale to Denafrips enyo 15th.
I wish we have this price here in Poland. $4000 is after discount. Regular price is $5000.
Buy a pair in Denmark and get them to ship them to you (shouldn't be difficult)
They have a live chat if you need to ask if they can send a pair to poland
Reactions: mike1986
That is quite an idea, thanks!
I haven't heard the Duetto speakers, but I have the Sonetto II G2 and absolutely love them.
What do you power them with? Do you think that NAD M10 v3 will be enough?
I use a Leema Tucana 2 which is more powerful than the NAD, but 100W should be plenty. They aren't difficult speakers to drive tbh.
btw they are 414mm tall so the stands I use, Kanto SX22, are 550mm rather than 600mm like most are.
Reactions: mike1986
Thanks to @gasolin I'm getting Sonus Faber Duetto 😍
My only concern is this: my TV (Sony Bravia 8 XR80) has four HDMI ports:
HDMI 2.0 - free
HDMI 2.0 - PS3
HDMI 2.1 - free
HDMI 2.1 eARC - taken by Samsung Q990F soundbar
Now, can anyone tell me, if I can connect Duettos to HDMI 2.1 port if that particular port doesn't support ARC or eARC?
HDMI 2.0 - free
HDMI 2.0 - PS3
HDMI 2.1 - free
Personally I would have read the manual before purchasing said speakers........
Not my area of expertise but do active speakers require ARC??
surely it's one way traffic?
I guess it depends on the data stream you are likely to be sending to those speakers.
HDMI 2.0 - free
HDMI 2.0 - PS3
HDMI 2.1 - free
If it doesn't support ARC/eARC then no.
Just use the TVs optical out into the Duettos
But then only 16bit/48Hz... that's the bandwidth of my TV's optical output 😫
I presume you are not going to be using those speakers and soundbar at the same time?
Get some sort of switch?
That said HDMI should be sufficient otherwise why would the Duettos be fitted with that socket in the first place?
Or is it an eARC socket they have?
EDIT: it seems that it is ARV/eARC.
Suggest reading this review.....
