HDMI lead - is it worth paying to upgrade?
I only need a 1 metre HDMi liead from my Toshiba EP35 to TV, and wondered if I should upgrade the cable or whether the cable supplied by Toshiba is good enough? I don't want to spend £50 if it makes no difference.
does it work?
then ll the digi engineers will say it will not get any better than that. but then some people will say that you will see a difference..... So if it does not suit your set up ie too long sure replace it but spending more more will not change anything. (unless it is of a lower standard than is needed).
Thank you, as I thought really. Saves me spending £50 on the QED as recommended by this mag.
Thanks again.
Just a thought, get a subscription to WHF, £20-odd for 6 months, get a free Chord HDMI......
Yes they do improve the picture.
I bought the Qed cable 18 month ago and was so impressed by it I bought the silver version and put the Quinex onto my 360. I run the cable from Sky HD box to Pana plasma.
Ravers idea is a good one.
Brent
