- Aug 10, 2019
- 2,556
- 4
- 0
I have a Sony 46X 2000 HDTV in a fairly small dedicated TV room, with a Sky HD box and an effective surround sound system (Pre-HDMI) with decent Polk speakers.
However, a Panasonic PT-AE 2000 projector just bought (following Clare Newsome's advice in previous correspondence) will have to be installed in another room which can accomodate the screen and projector. A PS3 player playing Blu-Ray DVD is portable enough for viewing in either room as required. I am also resigned to the fact that I need to buy a second cinema surround sound system for the projector.
But my dilemma is how do I get the Sky HD signal to the projector from the TV room . One question is (as Ski multiroom monthly rates can be quite expensive over a long period) will Sky allow me to buy a second HD box and keep just one Sky card which I can swap around to the room of my choice, since I can only watch in one room at a time?
Alternatively what is the maximum working length of an HDMI cable. I have bought a 10m cable, but the distance between the rooms may require about 25m of cable. Can cables be connected using for example, an Onkyo Surround Receiver to make good cable losses? Any comments please.
