I have them in my den, it's a small 12 ft x 10 ft room. High and mids are superb. Bass is crisp and decent, and I'm surprised the sound comes from these tiny speakers. You can throw pretty much anything at them: jazz, hard rock, electronica...(I listen to a huge range), and they shine. For a slight upgrade, you can also consider the S2000 Pro, but price wise that's nearly double. For smallish rooms, I think R2000 DB is excellent. I'm surprised it's not mentioned more often on these forums. Edifier has nailed it.
My living room speakers are Kanto TUK, and my next pair will be the more bass-rich and yet sharp as a tack, the Edifier S3000 Pro, which I've heard at my friend's place. But both of these are overkill for small-ish rooms.
PS: All these speakers are brilliant with movies. Fury, for example, or the acoustically magical, Gravity. These movies are very different in their audio signatures, and R2000DB rocks with both of them. I highly recommend it for modern apartments.
