Dutch?Hey, I'm trying to install a ground wire to my Sl-q200; any suggestions for me???
If the turntable requires a ground wire their is normally a provision for one without the need to take it apart plus you're normally trying to ground the tonearm not the turntable itself. This is why I asked about what is on the rear of deck.Dutch?
I asked as his name sounds very dutch ( Holland )If the turntable requires a ground wire their is normally a provision for one without the need to take it apart plus you're normally trying to ground the tonearm not the turntable itself. This is why I asked about what is on the rear of deck.
doesn't it, however " The surname Blankensop is a habitational name from the village of Blenkinsop in Northumberland, about one mile from Greenhead"I asked as his name sounds very dutch ( Holland )
I was assuming the ground wire was missing so he cannot connect it.....What is the problem? Just connect it.
manual https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Technics-SLQ-200-Owners-Manual.pdf
I try to never assume anything. As the T4P turntables from technical had two different ground wire fittings the OP needs to ID which that turntable has and then get a new one if it is missing. Or if it is there, IIRC my old one was a thin wire with a black cap, one end and a horse shoe fitting on the other, plug it in.I was assuming the ground wire was missing so he cannot connect it.....
Either that and it does have one but he doesn't know what to connect it to. All in all not a very helpful post.
Y'all I purchased the turntable from ebay. I didn't know it didn't have a ground. It does have the RCA cables, so can i just attach a wire to one of the RCA cables? I don't know that much about how it works. I guess you have figured that much out. So can I just do that? And to which one if the answer is yes. Oh and BTW... blankensop is my husband's ancestral name.Hey, I'm trying to install a ground wire to my Sl-q200; any suggestions for me???
The Owners Manual kindly provided by nads shows there is a connector for a ground lead next to the phono output sockets on this deck. You will need to make up a piece of wire to connect to this socket . I am not sure what type of connection it is, it may simply be another phono plug or mini-jackY'all I purchased the turntable from ebay. I didn't know it didn't have a ground. It does have the RCA cables, so can i just attach a wire to one of the RCA cables? I don't know that much about how it works. I guess you have figured that much out. So can I just do that? And to which one if the answer is yes. Oh and BTW... blankensop is my husband's ancestral name.
