Also, that they might be overkill for the size of the room they're going in. Looking at the spec, I'd image I'd never have them cranked above 30%!
JMac said:What concerns me about the opels (and other monitor speakers) is how do they perform as a pair of hifi speakers, if you will, rather than stuido monitors? Whats the imaging, soundstage etc like. I know this sounds a little odd, but I find that sometimes clinical reproduction of the source isnt the best or most enjoyable listen in a home environment and sometimes you want the speakers or amp to add their own stamp to the proceedings.
Craig M. said:I used to own Opals. I think you should demo some traditional hifi and then compare the best you can find at your budget against the Opals. And then buy the Opals once you've got over the shock of how much better they are. You could also look at Avi ADM9 plus the dedicated sub - without the sub they'd possibly roll off a little early - no need for dacs or anything else, the ADM9 has it all included.
If you haven't seen it, here is a thread that might put your mind at ease as to whether the Opals can do the 'hifi' thing. http://www.hifiwigwam.com/showthread.php?77756-The-next-mammoth-review!-The-Event-Opal-Studio-Monitors
JMac said:Reading the reviews, I'm coming around to the Opals. They might not be the prettiest thing out there but they certainly seem to punch above their weight quality wise. The only proble would be the fact that I'd need to spend more than my budget if you include a new DAC to control them
JMac said:Its the output that is actually putting me off them. They'll be used in a relatively small room that I use as a home office. Its an L shapped room and the area where I sit and listin/work is only probaly 6m x 4.5m in size. There is the remainder of the room behind me but that is being used for storage.
JMac said:Can I ask why you got rid of them if they're so good?
davedotco said:This is easy.....
These..........
Event Opal, dead on budget at £2300.
Massive power, bass response to 35hz, capable of levels in excess of 111dB.
Zero bling, serious sound.
JMac said:Looks like I need to find a place where I can audition them.....
What have people used in terms of DAC/Pre amp to take the signal from the PC to the speakers? I've seen people use RCA to XLR converter cable straight from the DAC, is that adequate? I dont mind replacing the DAC but if at all possible I'd like to get a few months use out of it as the Events would wipe my budget out.
Esra said:The Adam ...x can be very bright.I didn´t liked them at all,way too bright and you have to sit 2m to them to get a good sound.Very narrow sweetspot.They are maybe good for highly damped studios but not for home hifi.I would much prefer the Mackies or JBL which have a remarkable bigger sweetspot in terms of studio monitors..Event Opal are great but expensive and can easily overpower the room if it´s small enough.For that kind of money you get also great "normal" hifi ,expecially sec.hand.I can order a pair Opal Event for 2400 Euro.Just make a call if I should provide the dealer adress.
davedotco said:Esra said:The Adam ...x can be very bright.I didn´t liked them at all,way too bright and you have to sit 2m to them to get a good sound.Very narrow sweetspot.They are maybe good for highly damped studios but not for home hifi.I would much prefer the Mackies or JBL which have a remarkable bigger sweetspot in terms of studio monitors..Event Opal are great but expensive and can easily overpower the room if it´s small enough.For that kind of money you get also great "normal" hifi ,expecially sec.hand.I can order a pair Opal Event for 2400 Euro.Just make a call if I should provide the dealer adress.
That is entirely the opposite of my experience. In almost every aspect....... :doh:
The ribbon tweeter is ver smooth and integrates well in the overall design. Horizontal dispersion, is excellent, particularly so at high frequencies where domes become more directional, in fact I have never known listening distance to be an issue with Adams at this level. They have a range of controls to help with positioning and general balance, they are among the most user friendly speakers I have ever used.
Whilst I like the Mackies for what they do, I find them a little unrefined, particularly at lower levels, I generally avoid the modern cheaper JBLs, whilst I am a huge fan of their 'vintage' models the modern versions do not really do much for me.
