fr0g said:johngw said:Clear nobody else knew what they are doing. Until the cover was blown when someone picked the ADMs apart and measured the amps to 80W or less, i.e. in line with most of the rest.
Not really a fair comment. I imagine the power specs are given for the particular driver they use, which seems reasonable to me. What's the point giving specs into 2, 4, 8, 16 ohms when the amp will never be used with any other driver?
The chap measured the driver's resistance to 8 Ohm. He also demonstrated that the amplifier clips at 36V for a peak power capability of 162W and a max average power capability (RMS power) of 81W. The videos are on YouTube.
fr0g said:And if you turn the volume up, you can tell that there is PLENTY of power and then some.
No disagreement there! 80 genuine watts directly on the driver is still massive.
