12th Monkey
The non-anniversary - which seems to need more space and also represents a significant cut in speaker budget.
Hi everyone,
Over time, i've invested a lot of time and money in my hifi set-up. It's not a high en set-up by any means but it still has a cost for the average joe like myself.
The thing is though that I'm not getting much satisfaction out of it.
I based my initial research on forums, youtube, Whathifi and a listen at the local hifi shop and ended up going for a Cambridge Audio CXA60, CXC and Dynaudio Emit M20 speakers. Although I can see why these are all considers good buys, they don't work for me as a combo. I listen to a lot of bass heavy hip hop and electronic music and this hifi system doesn't give me my fix.
I've since got lost in the reviews and discussions about what to do..Should I replace the amp with a warmer, deeper sounding one? Should I switch the speakers because they're too bright? So many questions and every day I get lost in all the different solutions available. Thing i don't want to do, is spend some more dosh and end up getting a similar result.
I'm thinking the speakers are probably the main cause here and i've been looking at the KEF Q350s and the B&W 607s to replace them but will this help?
I also thought about swapping the amp for an IOTAVX SA3 or the DENON PMA 600NE but that could be the second step of my journey.
All thoughts are welcome![]()
In all honesty, if the OP was like me back in the day and it sounds like he is then the best sounding system isn't necessarily on top of agenda but dynamics and quantity certainly were sound quality was a plus just so happened it did sound good, different strokes for different folks and all that.Buchardt s400 can play bass.
I do like bass, i would rather go for the quality than the amoung of bass or the ultimate depth, i mean how many rock,pop,jazz songs have bass under 40hz, why strive to get bass under 40hz let alone 30hz, when you need alot more wattage to get good deep,clean and loud bass (i will spare you from a video), can your room handle it, for bass under 30-40 hz to be perfect you need a very big room, something physical with the lenght of the room equal something times x+y....... if the speakers are close to the wall the are playing towards the bass will reflect of that wall, mabye even make it boomy,muddy
Hi sirHi everyone,
Any info on this? ThanksI was looking at the ELAC Debut 6.2s with a front port (even thought they're a step down from the M20s) but i noticed that the Nominal Impedance is 6 Ohms whereas my Cambridge CXA60 has a power output of 60W into 8 Ohms and 80W into 4 Ohms.
A. What does this mean?
B. Is it an issue for me if I buy the speakers?
I've ordered the Elacs off Amazon and should be getting them soon. I'm curious to see if they'll make any difference at all...but I'm dubious. Worth trying out a front port speaker though.The lower the impedance, the less there is for the amp to 'push' against - but this isn't a fixed figure - it will vary fr a given speaker depending upon where you are in the frequency range. A speaker with low impedance and low sensitivity (the Elacs seem to be 87dB w/m, which isn't particularly sensitive) mean that generally speaking, higher power might be necessary to get the best, particularly if you want volume. But in of itself, impedance means little and a mismatch between amp and speaker isn't an issue.
Tat said, the Dynaudios are an even tougher drive, so if volume isn't the issue with them, it shouldn't be with the Elacs. Them being considerably cheaper could be, though. Will you be able to audition soon?
I had to make a choice. If the ELACS don't do it for me, I'll send them back and then maybe check out the KEFsSpeakers last if not abused - I'd have been keen to at least hook them up and see how it sounded.
I like a penetrating, vibrating bass rather than the thumping bass that I’m getting right now. I listen to a lot of hip hop and electronic music and the warmth and full bodied bass of that type of music isn’t apparent with current set-up. It all feels too bright and analytical and would probably be more suited to opera or soft rock...which is what I suspect the designers actually listen to themselves. I can just imagine the folks at Cambridge audio listening to early Genesis or a live version of Pink Floyd’s The Wall (I say this with humor before anybody berates me - I like that stuff too).I fear that's as much a consequence of them being further down the food chain as anything else. A pity, as my first experience of kit is seldom changed much with familiarity.
Two suggestions:
- Borrow those KEFs - you've nothing to lose.
- Try to describe what's wrong with the bass - I don't really understand what your problem is (or how you want it to sound but feel you aren't getting) - without that you might end up flailing about (wasting time, energy and possibly money) without reaching a happy conclusion.
I just think realistically you're not going to get that sort of bass in that space, no? And @TK421 if you mean Kef R300, that will be a bad choice, i literally did the same and that space will starve them of their performance. The bass will be boomy and the whole speaker restrained. Also you'll need a better amp to drive them.I'm wondering if 'penetrating, vibrating' bass means the sort that you can feel in your chest at highish volumes. If so, standmounters are not going to deliver.
I mean the Q300 that are front ported...ThanksI just think realistically you're not going to get that sort of bass in that space, no? And @TK421 if you mean Kef R300, that will be a bad choice, i literally did the same and that space will starve them of their performance. The bass will be boomy and the whole speaker restrained. Also you'll need a better amp to drive them.
