eggontoast
That's a damn shame, a real oversight IMOprofessorhat said:I've read from someone on the beta test group that it's not possible due to a hardware limitation I'm afraid.
I agree that 1080i is the best compromise setting and gives the best performance out of all the settings.professorhat said:Strange that you should find such a marked difference, but I guess it all comes down to your TV - on mine, although 576i is a tiny bit better for SD sources, the difference is so marginal I just use 1080i for everything so I don't have to keep changing.
Yes I have a one-for-all x-sight I just haven't got around to setting it up yet.professorhat said:Would it be worth buying a remote with macro / sequence functionality (e.g. the Logitech Harmony ones) so you can just have a button assigned to a macro which sends the correct sequence of buttons to change the resolution to the correct SD setting and another to change back?
Not sure if this has been mentioned anywhere else but if you use the 'power saving' standby mode it disables the RF pass through ??? that is just ridiculous.
