Floorstanders or wall mounted?
hope someone can help.
playing around with ideas of how to upgrade/change system at the mo, had my current set-up for 3 years, and this might sound a bit thick
Are floor standing speakers a better option for front speaker on 5.1 as apposed to wall mounted (which I currently have)
at the moment my sub (Mordaunt Short 308 avant) does a good enough job, but with floorstanders with I get any more punch in the bass department?
Andy Clough
776
Not a daft question at all. Yes, floorstanders will generally offer more bass depth than wall-mount speakers, so it might well be worth considering an upgrade for your front speakers.
Which speakers are you running front and rear at the moment?
cheers mate,
front,rear and centre are beech Gale's, had for 'bout 3 years now, did it all on a budget, as I still am,
About £150 and under for a set of floorstanders. I know it doesn't sound a lot. told you i was on a budget. any ideas?
