Vladimir said:If they keep taking design tips from B&W and Tannoy (my two favs) I may actually buy a pair of KEFs someday.
CnoEvil said:Vladimir said:If they keep taking design tips from B&W and Tannoy (my two favs) I may actually buy a pair of KEFs someday.
Until then, you'll be missing out. 😛 😛
science101 said:Interestingly enough however nobody has mentioned the Sonus Faber as a possibility?
With what would you guys pair the Venere 2.5 for instance?
:cheers:
science101 said:Vladimir,
I've been checking it out but in the brochure that I have there's no Rotel RB 1570. I have only either the RA 1570 or the RB 1572 (or the RB 1562 which seems very similar to the 1572 but with less power per channel), which one of the two did you mean?.
Cheers! :cheers:
Covenanter said::cheers:
CnoEvil said:science101 said:Interestingly enough however nobody has mentioned the Sonus Faber as a possibility?
:cheers:
I did in my first reply, along with some amps.
tino said:If I were starting out and wanting a 'stylish' low living room impact / all-digital system, I'd be looking at the following options that are about half your budget:
* Linn Kiko System
* Cyrus Streamline II + Triangle Color Floorstanders
science101 said:Covenanter said::cheers:
Marantz PM 8005 - see my thread http://www.whathifi.com/forum/hi-fi/living-with-it
Chris
:cheers:
Covenanter said:science101 said:Covenanter said::cheers:
Chris
Do you think that would pair up nicely with the Naim NAC-N 172 XS or would you get rid of the pre-amp and just use the
stream magic 6? To be honest about it I could rephrase the questions as: is a pre-amp really useful with my set up?
:cheers:
science101 said:tino said:If I were starting out and wanting a 'stylish' low living room impact / all-digital system, I'd be looking at the following options that are about half your budget:
* Linn Kiko System
Thanks Tino,
I didn't feel that taken by the Linn Kiko, but the second option that you mention will definitely be on my short list.
science101 said:Thanks for the suggestions musicraft. Yes I was thinking about going for the Naim pre-amp/streamer (in which case I suppose a Naim power amp is a good idea).
Also, the stream magic was the streamer that my friend had suggested. I have a feeling though that the speakers in both configurations that you mention would have a big impact in my room... perhaps too much for the wife!
:cheers:
