First Home cinema purchases
My girlfriend and I are looking to purchase a new Surround amp and speaker package, at the moment we are just looking at speakers from Mordaunt short the 308i premiere package, there around £300, or the Mission M33i m30i M30cs combination, which is around £380. Anyone own these packages? If so which one is better, these will be used soley for movies... Any info on different speaker packages for around £300 that you guys know about that are good?
Cheers L&J
grdunn123
293
6
18,895
Hi, firstly what size is your room? I have the Mision M33is with the matching centre and Mission d77s rears in conjunction with my Onkyo receiver. If you have a big enough space, eg, at least 5x4m then the Missions are great. Any smaller and you'll be overwhelmed and the Kef package would be a good bet.
I have the mission m33i fronts and the m32ci centre m30 rears but I have added some monitor audio br1's as rears in a 7.1 setup.
I have to say the missions sound superb clear and detailed for the money. My room is 20' x 10' and they fill the room just fine. I have never demoed the kef's so I cant comment on any quality differences but I do prefer the sound of the bigger box speakers.
As mentioned above dont forget to add in cable, Banana plugs (if you want them) optical hdmi cables etc. I personally rune some £10 a meter cable to the front and centres for quality and as the rears are mostly ambience and because I needed 50mtrs I only spent £1.50 a meter on the rears and it sounds just fine.
The Mission package sounds just fine and bassy as it is but you will might need to add a sub depending on your room size as there isnt one in with the package I personally use i wharfedale sw150 £150 but i have heard that the bk gemini's are very good too oh and dont forget the sub cable
thanks for the replys guys, we have all the cables already. Going to demo the Kefs and the Q- Accoustics 1010i's which my gf likes and there only £300, Any advice on some budget DD5.1 amps? I've not read up about them for ages....
I recommend the dh800 as its what I use but it is a bright sounding amp and I demod the q acoustics set and found them bright too so i dont think they would pair well with the sony but try to demo if you can as we all hear differently.
didnt get chance to demo the speakers n amp today but we booked it for tuesday next week, Wanted to test the sony800 but richersounds never had it in stock, so i went for the Onkyo 308 - what you guys reckon on that? WHFSV gave it 4/5 stars, so it cant be that bad, pretty set on the Kef's as the 1010i's look too oldskool... but its all about the sound, also blu-ray players... the sony BDPS370?, or is the LGBD390 worth the extra £50???
TIA
PS the room is around 4.7m x 4.3m (15ft x14ft) - Reckon the Kef's can fill this space?
dirtydean
69
foxorroxors:
TIA
My room is a bit bigger and sound well in there, I went to comet to listen to the kefs before I bought them. There testing room was about that size. Have a tip down to comet and see if they still have them, it has to be one of the big comets though .
Dean
Sorry can not help with the blu ray player
steve_1979
231
10
18,795
I highly recomend the £300 Q Acoustics 1010i 5.1 speaker package. I've just bought them myself last week and they sound absolutely fantastic! They look and sound like they should cost £600 not £300!
Don't forget that these speakers will sound best if you use with them with stands. Expect to pay about £100 for a set of 4 decent speaker stands - money well spent in my opinion.
www.richersounds.com/product/speaker-packages/q-acoustics/1010i-5.1/qaco-1010i-5.1-pack www.whathifi.com/Review/Q-Acoustics-1010i-51/
sta99y
137
Hi as for bluray I had a friend who d‚mod‚ me the LGBD390 and panny BD85 and the pic on lg was fab! Also YouTube, 1gb storage and wireless. I have it set up via anolouge outs and it blows me away. Go for the LG at RS £169 at mo!!!
