Craig M.
i'd be willing to put money on it you couldn't pick them out blind. where do you live? if it's not too far i'll come and do the swapping about...
roger06 said:I'll try the Maplin power supply upgrade for the rDAC and continue to see if it need running in
roger06 said:It's either the Apple TV, the NAS, the network (wired) or the rip (apple lossless) – so just a but more detective work then!
I have demoed the rdac at home for couple of days and it did not better the onboard dac of my cd192.Probably it is better to use rdac on computer base system IMO.roger06 said:Well it's been a long wait but the rDAC finally arrived this morning.
Will report later on what difference it makes in Apple TV ->rDAC -> Naim Nait5i setup compared to the current AppleTV -> Yamaha AV amp -> Naim Nait 5i.
manicm said:roger06 said:It's either the Apple TV, the NAS, the network (wired) or the rip (apple lossless) – so just a but more detective work then!
In my biased opinion it's Apple Lossless - try AIFF just as an experiment and see if that makes a difference.
roger06 said:manicm said:roger06 said:It's either the Apple TV, the NAS, the network (wired) or the rip (apple lossless) – so just a but more detective work then!
Okey dokey - simple enough to try...
Craig M. said:i wouldn't be too bothered, they sound the same.
roger06 said:Craig M. said:i wouldn't be too bothered, they sound the same.
I'll never know!!
Overdose said:So the total cost is nearly as much as a Rega DAC so far?
