I read an article that Ferrites added to any cable that carries signal makes a huge difference
Sales Hype or does it work? They only cost approx £4 each
chebby said:We don't have any problems with rabbits so they aren't necessary.
Superaintit said:
I use them and too good effect too.
Bought them just out of curiousity. The result is very good around mains cables in my house. Just read up on wiki pages, buy a few and report back what you think.
Superaintit said:I use them and too good effect too.
drummerman said:I use them, in different sizes, everywhere, even inside cd players and amplifiers and have done so for a long time.
dim_span said:you need the Multicomp 10MHz-300MHz ones
buy them (they cost just over £3 each) ... and see if they work or make a difference
if they do, I will buy some *biggrin*
TrevC said:dim_span said:you need the Multicomp 10MHz-300MHz ones
Mae a difference to what exactly? What interference are you wanting to reduce?
dim_span said:TrevC said:dim_span said:you need the Multicomp 10MHz-300MHz ones
I'm not sure thats why I'm asking ...... the article said that when these ferrites were placed on speaker cables the following happened:
huge difference in focus
TrevC said:The link doesn't work, but I can imagine the nonsense that I would have read if it did.
dim_span said:I'm not sure thats why I'm asking ...... the article said that when these ferrites were placed on speaker cables the following happened:
Covenanter said:I've never thought of using ferrites to improve my sex life. Do they make them with a 3" diameter hole in them?
Chris
