I bought a new Kandy LIII amplifier recently but have had to return 3 units with the same problem. After about 2 days use, the volume starts to fail and goes louder / quieter and only though one speaker. When you try to use the volume control, the sounds just comes in and out, too loud and crackles.
I contacted Roksan and they are aware of a fault on some units that they describe as a ‘Volume Port Problem’.
Anyone else had this problem or just me?
Cheers.
Cheers.
