Hey all. First of all, I know this belongs in the TT subforum, but that seems to be geting very few visits. So.
Has anyone heard it? I want to upgrade my TT and for reasons that would take too long to elaborate and are irrelevant, my options are the Electrocompaniet ECG1 (though this would really, really stretch my budget) or the new Rega Planar 6. The cartridge choice will depend on the matching, of course, and the phono stage will be a budget-ish one for the time being, until I can start considering something like a Croft or a Rega Aria.
My main problem with the PLX1000 is that it has pitch stability problems, which diminshed after a trip to the service (they changed everything in the motor assembly), but not enough for my ears. I know that, in theory, belt drives should be even worse, but with all the great reviews belt drives are getting, it can't really be that bad, can it? On the point of pitch stability, I'm not really considering the new Technics SL1200GR because, with all the mods, I wouldn't be able to stop myself from wanting to upgrade - arm, power supplies etc. Also, I'm not looking for CD-type playback from my TT, if you know what I mean.
Oh, and here's the rubb: I can't audition either.
Reading around, led me to believe that the Electrocompaniet might be better suited for jazz and classical, even if it is the better overall performer. I know a lot depends on cartridge and phono as well, but I don't know in what measure - I mean I do listen to the occasional Jazz and Classical record, but it's mostly Prog Rock, and I don't want the sound to be all smoothed out, even if the soundstage and euphonics are better etc.
So I do want energy from it, but not at the cost of having a "smiley EQ". Present midrange, punchy bass and extended but not grating highs - and just a bit on the forward side, and with good momentum, timing, flow, whatever. Will I be able to achieve this with the Electrocompaniet without replacing the Jelco tonearm? And, without necessarily comparing to the Electrocompaniet, how close would Rega P6 + Nagaoka MP500 be to achieving my goal - and should I go for a more neutral/forward sounding phono pre, or a warmer one?
Thanks all.
Thanks all.
