You may think this question has already been answered a hundred times, but I couldn't find a decent answer, because these two models are generally considered too different to be directly compared.
I'm hesitating between the Beyerdynamic DT 770 Pro 80 Ohm and the 990 Pro 250 Ohm
I know the sound quality would be superior with the 990 250 Ohm, especially the soundstage.
But, if I don't want to cope with some aspects of the 990 (open back, coiled cable, required amp), I'm wondering how much of a sacrifice I would make by going for the 770 80 Ohm in strict terms of sound quality.
Would it be just a little less amazing, half as good, etc?
I'm mostly listening to minimal techno, house, pop, not much rock, no classical music.
If I go for the 990 250 Ohm, I would only use it at home with an amp; if I go for the 770 80 Ohm, I would use it everywhere without an amp.
