Benedict_Arnold
- Jan 16, 2013
- 661
- 3
- 0
Fitting front highs or wides?Probably not.
The front in walls are set fairly high up in anticipation of having a 4k PJ and 136 inch 21:9 screen (roughly 11 feet by 5 feet overall) probably some time next year. As this will almost reach the ceiling as well as covering virtually the full width of the wall, front highs or wides wouldn't be possible.
The "proper stereo" floor standers are also too low.
I do agree with you that having four in ceilings in my size room probably is overkill, but given the speakers I used, which are more than adequate for surround sound but certainly not audiophile stereo duty, were only US$120 or so a pair, and given I had to put two cables up though the wall, across the top of the ceiling, etc., AND given my receiver can do 7.2.4, why the heck not install all four and be done with it and not regret not doing so later?
What I should have done, with 20/20 hindsight is to not install the first pair (with the wiring pre installed by the builders) half-way down the room.
Those will probably be coming out, as and when I can be bothered to fix the resulting holes in the plasterboard and "popcorn" finish thereon.
Unless, of course, next year's big thing is IN FLOOR speakers....
