bigboss
Moderator
What do you mean by "ceiling speakers sounding fake"?ellisdj said:I think ceiling speakers generally sound fake anyway but height speakers such as in auro actually add to the presentation.
Have you seen the number of blu ray titles released and upcoming on Auro 3D compared to Atmos?ellisdj said:Sorry BB rushed post - we have debated this before I am not sold on atmos speaker layout but I do like the auro 3d speaker layout.
ellisdj said:Think about it the sound doesn't only echo off the ceiling it echos off every other surface as well. That completely negates the effect think about it
Thanks for confirming that!nugget2014 said:Examples being lightning from a scene in BvS (by the way big boss the wonder woman soundtrack did seem a tad quieter on atmos compared to truehd i believe you asked that before?)
bigboss said:Thanks for confirming that!nugget2014 said:Examples being lightning from a scene in BvS (by the way big boss the wonder woman soundtrack did seem a tad quieter on atmos compared to truehd i believe you asked that before?)
You're welcome to demo my system.ellisdj said:I am talking by he difference between having something for the sake of having it or adding something to your system to make an actual tangible and measurable benefit.
Agreed.nugget2014 said:All that matters essentially for atmos is that sound is essentially coming from above you which it does sound like.. it's good enough for me i think! Considering i can't have ceiling speakers it will have to be..
ellisdj said:Ceiling speakers maybe in a huge room such as a cinema to fill in the big void in the speaker arrays
bigboss said:What crossover have you set those speakers at?f1only said:Well on my Pioneer amp in the settings it asked me to measure the distance from the speaker to the ceiling then to use the Pioneers automatic MCACC setup using the supplied mic, it then measures the total distance of the reflected sound, this has worked fine for me. Also as far as i'm aware it is best to always use the same make speakers for the best effects.
High & low frequencys bounce just to a different extent off differing meterials, i know this as i worked on a marine seismic oil & gas research vessel for around 10 years & we used sound reflected off the sea bed from explosions created by us using various explosive methods including dynamite, Nitro carbo nitrate & air guns running at 4,500 psi to determin what was down under the sea bed.
As far as the Speakers i am using, they definately work better than the Onkyo Atmos speakers i purchased ever did at £129.99 even though the B&W were £350 per pair so yes they are cheap crap i suppose, but do the job for me as they produce more HF & bass than the onkyo's could ever put out & controlled by the amp.
That's interesting! Just wondering if you're getting better performance on account of extra speakers instead of Atmos effect. The lower frequencies cannot bounce off the ceiling, so the extra bass is due to the presence of extra speakers. I suppose the higher frequencies bounce off the ceiling for Atmos effect. Doesn't this result in a muddled up sound coming from the speakers themselves as well as the ceiling? Or do you think it adds to the effect?f1only said:bigboss said:What crossover have you set those speakers at?f1only said:Well on my Pioneer amp in the settings it asked me to measure the distance from the speaker to the ceiling then to use the Pioneers automatic MCACC setup using the supplied mic, it then measures the total distance of the reflected sound, this has worked fine for me. Also as far as i'm aware it is best to always use the same make speakers for the best effects.
The crossover is set at whatever the amps given them on the MCACC.
All my speakers are set to small but you can not set the TMdr Atmos speaker size so i am assuming it is a default.
As to the hight i measured them for the amp at around 1.2 meters from the ceiling & after callibration it now tells me they are 3.67 metres from the main listening position given the reflected distance. Which i hasten to add is exactly the same as the Onkyo Atmos reading was, it is telling me they are over a meter further away than the speakers they are stood on so it's definately working.
Regards ..
f1only said:Hi BB
I've had a look at the amp & found the settings regarding the crossover frequency & it has set it at 150 so is chucking lots of the bass to the subwoofer, i can change it up to 200 which may make it sound better i suppose. I'm doing a rewire at the weekend so i'll let you know the result. It does defo sounds better though than the onkyo speakers did installed.
I believe they are the same size woofers or near as damn it on the 686's as the Kef Atmos speakers.
Regards ...
ellisdj said:19 x 12 is the same size room as mine roughly that is a small room
It does lend itself naturally to having 1/4 length spaced ceiling speakers but that is not the only option
Listen to the avf podcast where the owner of auro is talking about domestic speaker layouts and the importance of the screen end. The fact only 5 base layers are needed in a domestic room and the adding 4 height layers is enough in small rooms - but height not ceiling as the 30 degree angle of sound is more natural that sound from above your head which is not
Then think what you have just said about only needing 2 ceiling speakers as 4 are not differentiating themselves then think right have I used my 4 additional speakers to the best benefit of the sound overall of my systems presentation
