davidf said:“Dual mono” means that each channel is completely independent of the other, and shares no components at all, unlike a normal amplifier where at the bare minimum, both channels would at least be fed by the same transformer - each channel is a completely independent amplifier in itself from the start of the input to the output, including its very own transformer. The channels are usually mirror imaged too.
I'm so sorry, I did. I must've read it and wasn't able to respond, then it slipped my mind.gisgillen said:Thank you all. Interesting. Insider9 assures me it is stereo, which is enough for me. Thanks. PS insider9, in our recent correspondence regarding the Musical Fidelity, you suddenly gave up on me?!
insider9 said:How have you been?
Good stuff!Vladimir said:insider9 said:How have you been?
Doing great. Hope you are well and less bored than I am. *ok*
insider9 said:Good stuff!Vladimir said:insider9 said:How have you been?
Bored? No, not at all. I've got Esoteric F-05 in for a review so won't be bored for a while.
It might even keep you guys entertained 🙂
Vladimir said:That's mouth watering impressive looking amp. Is the F-05 the Class AB version?
insider9 said:Vladimir said:That's mouth watering impressive looking amp. Is the F-05 the Class AB version?
Indeed. It is class AB. Let me bump that thread with some pictures so you can see it.
Vladimir said:insider9 said:Vladimir said:That's mouth watering impressive looking amp. Is the F-05 the Class AB version?
Good choice. Going for class A with enclosed heatsinks usually is a big problem for a large integrated.
insider9 said:Vladimir said:insider9 said:Vladimir said:That's mouth watering impressive looking amp. Is the F-05 the Class AB version?
I'd need 3 people to carry it if it was Class A. It's 32kg plus a bit more for a chunky DAC board as it is. 120Wpc into 8 Ohms and 240 into 4 Ohms from 940VA transformer and massive caps. The box nearly doesn't fit through the door *biggrin*
More like it's to get the very best power supply for each channel.Vladimir said:The whole point of dual mono is better stereo separation.
