disappointed with sound
Hi your thoughts please just tried my new bx2s last night with my denon dm38 had 9.1s diamonds before was expecting a better sound to be honest they seem to sound the same as the 9.1s the system is on a shelf in my kitchen the speakers are up against the wall from the back i went for bx2s as they are front ported to help with the base should i sell the denon as well and buy marantz pm and cd 6004??? cant place speakers on stands as people have told me kitchen is the only place for system in my house comments please
regards Martin.....
anyway sand is a good idea but i have not got room for stands any ideas on my original question about sound
You could put the speakers on wall brackets like these if you have not got room for dedicated stands .
http://www.richersounds.com/product/speaker-stands-brackets/btech/bt77/btec-bt77
It should allow them to work better than placing them on a shelf and they can be adjusted for angle and tilt to get the best sound balance 🙂
My lord this is confusing the kitchen is my only room to have a system in reasons friends allways are in kitchen and kitchen back door leads to garden so when sat out there can still here music when turned up a little
thanks
thanks
I bet your neighbours are pleased about that? !!!! :wall:
CJSF
Well your speakers really are not going to work anywhere near their potential placed on a shelf, regardless of what's running them.Stands, or even wall-mounts, are going to make a night and day difference. I do appreciate, though, that a kitchen is an impractical - even impossible - location to site stands, but listen to Electro and look at wall mounts.
Well your speakers really are not going to sound anywhere near their potential placed on a shelf, regardless of what's running them.
Stands - or wall-mounts - are going to make a night-and-day difference. I do appreciate, though, that a kitchen is an impractical - even impossible - location to site stands, but listen to Electro and look at wall mounts.
Edit: Plus one for the B-Tech's. I have a pair, although I had to dispense with them due to masonry problems
How do you know he has any? I've got speakers in the back garden, nearest neighbour is half a mile away, ok with you if I turn them up a little?
Good point lucky for me i live in a castle with a moat round me !!
Live in the middle of a field The_Lhc? . . . With your attitude, no one would wants to live any closer to you . . . 8)
CJSF
As it happens, yes.
Or I them, if I'm being honest.
Going back to the OP. You certainly should get a better sound if you swap the Denon for the Marantz pairing - or, if you want to keep things compact (never bad on a shelf) the Marantz Melody Media (aka CR603) or Denon CEOL systems.
There are some superb deals on those systems at the moment, and you should hear a clear step up from your DM38 - and you'll add Apple AirPlay capability, allowing you to stream directly to your hi-fi from your Apple iThings...
thanks very much for your advice have just ordered pm cd 6004 from peter tyson regards martin.....
We agree The_Lhc, I dont like people much either . . . I dont know the names of either of my neighbours, been her 11 years . . . we do have a problem with some across the way, back door open, music blasting away, poor quality in sound and taste!!! :wall:
CJSF
