- May 25, 2009
- 41
- 0
- 0
Can anyone tell me is the digital signal that comes from an expensive/top end CD player is better than the digital output from a mid range/cheap CD player?
cheers!
cheers!
CnoEvil said:I suppose it depends whether you believe a well sorted transport makes a difference......which I do, but there is by no means consensus on this.
johngw said:CnoEvil said:I suppose it depends whether you believe a well sorted transport makes a difference......which I do, but there is by no means consensus on this.
I guess if the OP is genuinely interested he/she could bring their kitchen Tesco DVD-player to a HiFi dealer and A/B against an upmarket transport feeding into the same DAC. Maybe you should too - just make sure it's unsighted and no cheating!
mushroomgod said:basicaly I'm upgrading my gear. My (potential) new amp has a high end dac inc, and I was wondering if my £250 Nad CD player is worth upgrading.
johngw said:mushroomgod said:basicaly I'm upgrading my gear. My (potential) new amp has a high end dac inc, and I was wondering if my £250 Nad CD player is worth upgrading.
As stated already... I think your money is better spent elsewhere but you'll get plenty of conflicting advise on this so you'll have to decide who to trust - or perhaps more importantly - experiment yourself. Just don't buy into something without being certain it brings value.
Overdose said:Otherwise, spend your money elsewhere, such as on the speakers or maybe a streaming solution if you don't already have one.
mushroomgod said:Hi guys, cheers for the advice..
the general thought for me is I don't want to upgrade if it offers no benifit, and but the sounds of things th dac in the amp will be better than the dac in my CD player. All things being equal ill probably stick with it.
intresting that you mention streamers - I primarily listen to vinyl and music from my Apple TV (vr 1) and am looking to upgrad that at some point anyway.
BigH said:mushroomgod said:Hi guys, cheers for the advice..
Which amp. are you talking about?
