- Aug 10, 2019
- 2,556
- 5
- 0
Hi all,
Ever since I plugged my DacMagic 2 in to my Mac Pro the only sample rate it would detect was 44.1kHz.
I downloaded a 10 second sample FLAC encoded at 96 kHz to hear the difference in sound quality. When I hit play - within VLC - still the 44.1 kHz light remained on when surely it should've changed!
After a little bit of googling, I discovered a tweak that allows you to manually set the sampling output rate for the TOSLink port. You have three 'format' options; 44.1, 48 & 96 kHz.
I changed mine to 96 kHz and low and behold the light changed on the DAC immediately and it does actually remain lit on 96 constantly now. The sample file also sounded significantly better. Even sound from my Sky+ box benefited - as it transmits at 48 kHz. DVDs would also benefit from this I'd presume.
I can't say the sound on 44.1 kHz files/Spotify changed much, if at all though which I was expecting.
The application you use to change it is called 'Audio MIDI Setup'. You can find it via Spotlight or going to Applications>Utilities. You can leave something playing in the background and change the sampling rate on-the-fly to hear the difference it makes.
Hope this will benefit some of you using a Mac as your source.
