Hi there,
We are in the market for new speakers. We have the Dali oberon 7 home on trial at the moment, and also want to test the Triangle Borea speakers. We are a little in dubt as to wether the 08 or the 09 will best suit our needs. (this is our first speakers)
amp: Lyngdorf TDAI-1120
room: high ceilings (about 3.5 meters)
35m2
I dont think the extra bass output in itself is needed for us but are there other considerations when choosing between the two models.
- Do they perform equally well with music played at lower volumes?
- does the slightly higher sensitivity (92 vs 92.5) make a difference in combination with the amp that we should take into account
- We use it witout a subwoofer - and the br09 has a frequenzy down to 35Hz compared to 40Hz - will we notice a difference here (used for rock/pop, classical and jazz)?
thanks, Magnus
35m2
thanks, Magnus
