Did I just wreck my speaker
  • Thread starter Thread starter Anderson
  • Start date Start date
Anderson
I'm so annoyed at myself right now.
i was adjusting the feet of the speakers and to do so meant lifting them. I noticed something rattling which didn't surprise me because I've caught my nephew trying to stick things in the port a couple of times.
So I ended up removing the bottom woofer and with the aid of a little helper removed the offending materials, link to little album of this process.
Anyway, when I was righting the bolt at the back I heard a crack, like the sound wood makes when it splits. F&%K. I've investigated around the bolt in the outside and can't see any damage at all, not a hint. I've rapped the speaker around with my knuckles and it sounds okay, I tried removing the woofer again to see if I could see any damage on the inside but where the bolt comes through the crossover is attached and I don't see anyway to remove it.
Do you think I'm okay?
Those pictures made me laugh. Sweet looking daughter you have there too. 🙂
As far as your speakers go I can't help. I have heard wood crack without snapping before now so it could be possible that you've just weakened the wood a bit without actually breaking anything. This is only a guess though.
Nah you'll be reet. I wouldn't worry about it if you can't see any damage and everything works fine. Your assistant is mega cute. Much better than my two highly-hormonal teenage boys who just grunt at me.
Thanks, she's a little monster though hah
I hope your right, plus your explanation has settled my brain a bit. Stressed but not completed broken, this could be the case. 🙂
Probably ok but, you'll never be 100 percent happy with that speaker ever again 🙂
There will always be that niggling bit of doubt.
OMG you are my tormentor!
I've got 3 girls, I've no doubt they will all end up as hormone fuelled monsters. Just enjoying what little years are left until then 😛
