Gerrardasnails
cram:
Gerrardasnails:You were right the first time too.
I know i'm being nit picky and anal etc. but he wasn't right. He said "The amount of times i have said to people that theres just as much chance as the same 6 numbers coming out every single weeek forever, as there is as any numbers coming out."
Baring the machine breaking done it is absolutely guaranteed that a set of number will come out. The odds that it is the same set of numbers that come out forever is infinitesimally small, which is my way of saying I can't be bothered to calcuate it.
Lets take a very simple example. I predict that two tosses of a coin will both yield a head. Ignorning the statistical possibility of landing on the edge, the odds if me being correct are 1 iin 4 because there are four possible combinations. The odds of me being correct on any individual toss of the coin are 1 in 2 - so predicting across multiple interations is an whole different order of magnitude.
No, you are wrong. Each time you toss a coin there is a 1 in 2 chance of the result. If you are predicting a single result (like each Lotto draw, you are predicting 6 numbers, or each flip of a coin, there is one outcome), each time you do it, you still get one result. You could draw, 1,2,3,4,5 and 6, one week and then there is as much chance drawing the exact same result the next week as any other combination. Better example, roulette. You have 38(?) numbers and it lands on 3. The next spin it's still 38/1 that it will land on 3.
