Sake said:Anyone tested this one? How is the soundquality compared to now discontinued rcd m40 or other amplifiers?
nopiano said:I've no idea how it sounds, but for me - a regular CD user - putting the drawer above the display is an ergonomic disaster. I like to see which track I'm selecting, so unless it is mounted at head height, the tray obscures the display. The previous model did it properly.
My Marantz is the same, and had I realised what a stupid design it was I'd have chosen something else! You can of course count how many times you press the track button, but that's hardly ideal.
Gray said:Personally, when loading a disc, if I don't just press play, I do a quick multiple hit of the player's next track button to select a starting track and close the drawer. Call me a fussy old git but I'd rather the display was never blocked from view.
Gray said:The initial track selections he's talking about Doug. (The one(s) you close the drawer with)
chebby said:Gray said:Personally, when loading a disc, if I don't just press play, I do a quick multiple hit of the player's next track button to select a starting track and close the drawer. Call me a fussy old git but I'd rather the display was never blocked from view.
People advocating physical media like CDs are always saying how there is no substitute for playing the whole album 'as the artist intended ' compared to us streamers/downloaders who flit around skipping tracks all over the place just to play our favourites apparently.
Exactly my point. Thank you!Gray said:True what you say Major.
When I'm back home I'll check, but I have a hunch it begins to play, not just read the index, when you close the drawer. However, if you're correct that might be a solution. It's just I was used to popping the disc in my Krell, selecting the track if I wasn't playing a whole symphony, say, then presing play. But when the drawer is open you can see which track.DougK said:Gray said:The initial track selections he's talking about Doug. (The one(s) you close the drawer with)
Yeah, I understand, but Marantz remotes have a drawer open/close button on them. Once closed the screen is in full view *smile*
nopiano said:When I'm back home I'll check, but I have a hunch it begins to play, not just read the index, when you close the drawer. However, if you're correct that might be a solution.
Indded it does! I think I was simply used to selecting the odd track that way in my Krell, but with the SACD Marantz I cannot. It is very slow to read versus my old player, and for that matter the rather nice Roksan Caspian 2 that the dealer used for my recent speaker adventure. The Roksan also is drawer on top. TBH I prefer display and keys one side, with drawer the other - like some Luxman, for example. But symmetry rules for most.DougK said:nopiano said:When I'm back home I'll check, but I have a hunch it begins to play, not just read the index, when you close the drawer. However, if you're correct that might be a solution.
On both the Marantz spinners I've owned when you press the close button on the remote it just closes the drawer and starts the read function then sits there waiting patiently for your next input/instruction. I'm kinda hoping that yours does the same. The same also applies to the close function button on the actual unit.
