Denon AVR-X2200W Crossover settings?
Doc Bean
I recently bought a Denon AVR-X2200W receiver and the Q Acoustics 3000 Series 5.1 Cinema Pack speaker set. After setting everything up, I ran the Audyssey MultEQ XT calibration suite. The following are my crossover settings:
Front - 60
Center - 40
Surround - 40
Sub - LPF for FFE 120
According to the manual for the speakers, the Frequency response (+/-3dB) is:
Front and surround : 64 Hz - 22 kHz
Center: 75 Hz - 22 kHz
And the Crossover frequency:
Front and surround: 2.9 kHz
Center: 2.7 kHz
Sub: 50 Hz - 150 Hz (var)
Shouldn't the first three be higher, e.g. 80 or so? They are all set to Small and the Subwoofer is Yes.
B
BIGBERNARDBRESSLAW
Set your fronts, centre and surrounds to 80, otherwise they'll be working a bit hard, and as they're set to small, they'll lack bass.
Sub is fine at 120.
