bigboss
Moderator
The OP will lose out on surround sound for movies.Q5 said:I would go with David's suggestion, pure direct stereo mode, this will eliminate any auto setup getting in the way.
The front two are already set to full range.
bigboss said:The OP will lose out on surround sound for movies.Q5 said:I would go with David's suggestion, pure direct stereo mode, this will eliminate any auto setup getting in the way.
bigboss said:Is it blu ray or DVD?
Make sure your settings are right.
Check this link:
http://manuals.denon.com/AVRX2300W/NA/EN/GFNFSYvdfworfs.php
If this doesn't work, maybe it's time for a subwoofer! 🙂
bigboss said:bigboss said:Is it blu ray or DVD?
Check this link:
adamg64 said:I will try the checks tonight to be sure, the film was on netflicks via ps4.
I built the original system bit by bit, amp plus 2 fronts then added rear and finally centre, the sub was gonna be the last piece but as the setup provided a suitable level of bass there wasnt a need to add one.
Although its an option i have been considering adding now with issues im having but thats throwing money at the issue and not fixing what issue im having.
This might sound silly but i guess me video'ing it wouldnt give a true representaion of the sound im having?
1, Check your levels of the main L&R channel, sometimes auto setup can vary volumes between the main L&R up to 5dbs. This can give a distant sound some how lacking in bass.Q5 said:adamg64 said:I will try the checks tonight to be sure, the film was on netflicks via ps4.
I don't think a video will help, sound won't pick up or play back as you hear it.
Go back to basics, prove the speakers give you what you need bass wise and eliminate any of the auto setup.
play something you are familiar with and know the bass well, use this throughout your testing.
Make sure you use pure direct mode and single wire your speakers removing the option of Bi-Amp.
Floorstanders don't go as deep as most subwoofers. Adding a subwoofer will make a huge improvement to your system. It's the most important bit of a home cinema system IMO.adamg64 said:I built the original system bit by bit, amp plus 2 fronts then added rear and finally centre, the sub was gonna be the last piece but as the setup provided a suitable level of bass there wasnt a need to add one.
Having a subwoofer doesn't necessarily mean going louder.adamg64 said:I would be happy not sure about my neighbours tho!
adamg64 said:but there Bi-amp speakers? it tells me to do that?
macdiddy said:I have no idea where you get this information from that you have "bi-amped" speakers, I think this is where some of the confusion has come from, what you mean is that your front speakers are "bi-wireable" which means each speaker has two cables running from the back of each speaker to the front L+R terminals on the amp.
I'm sorry Q5 but for now we the most basic way of connecting the speakers to the amp, when adamg64 has the sound he likes then we can start changing things around.
*music2*
