Overdose:
I am soon going to add some more sockets in the living room, four doubles. The questions I have are...
[*]Would it be possible to incorporate some mains conditioning at this point, if it is needed, also what is available?
[*]How do you know if you have 'dirty' or 'clean' mains?
[*]Rather than add to the existing ring, would a dedicated ring or spur be more beneficial?
Many thanks in advance for your thoughts.
Answering your questions in reverse order, my thoughts would be:
3) A dedicated ring or spur (technically, a radial circuit rather than a spur) is always better for hi-fi/AV because most noise on an existing household circuit comes from a) other appliances connected to it and b) oxidised/loose connections which join the many existing sockets together as the ring snakes it's way around your house: Poor connections here also lead to increased impedance. A dedicated ring or radial gives you an unbroken length of wire direct from your consumer unit to your hi-fi with nothing that can generate noise sharing it (typically kitchen appliances, noisy heaters, table lamps etc) - other than maybe some of the hi-fi/AV components connected to it which can generate their own 'dirt' back onto the power line! In addition, a dedicated circuit gives you an opportunity to use wire which is much thicker than the standard 2.5mm cable - again, reducing impedance, and a much cleaner/robust earth connection (important!).
2) You don't unless you can measure it. An easy way to test for noise on a circuit is with a 'noise sniffer'. You can hire or buy them. But if you are going to run a dedicated circuit just for your hi-fi or AV equipment, it's best to do that first so you can test that circuit before deciding if 1) is necessary...
1) Yes, but it's likely that a dedicated circuit will in any case be much quieter than connecting your hi-fi/AV onto the normal household ring main. It's likely to be so much quieter that mains conditioning may be entirely superfluous, although spike/surge suppression is IMHO worth adding at minimal cost for peace of mind. This connects in parallel, is active only if there is a surge worth suppressing, and thus does not adversely affect the sound.
Hope that helps - I'm sure others here will have their own views...
