Just be aware that I think I contacted the same person from a shop beginning with A (two words in name) about a week ago and, on trying the P35 unit, it didn't work. He rang me to notify me and he said his engineer would look at it. Turns out it had a dry solder joint which he repaired. From looking at the net, a dry joint is a legitimate fault and probably occurred during manufacture.ÿ
The owner sounded like a good honest guy looking to wind down his shop (reason for cheap sale).
The shop was AO. I can give you the name of the shop if you want but haven't in case you want the bargain!. The guy was perfectly honest with me and I respect his honesty.
Not really joelsim. He said the original owner was minted and the arcams looked like new.
I'd go for it.
I have just had a tax rebate so I've managed to get some Ecosse MS4.45. The Proacs have moved into a different league! Much more 3D with the instruments sounding more real.ÿ
My P35 arrived today but there is no power cord with it so can't set it up. I'm very excited.
The missus said 'just what we need, another amp!'ÿ
Do men hear things differently?
Good luck with your purchase. I'd definately go for it at that price!ÿ
leenorris78:
I'd go for it.
JoelSim:leenorris78:
I'd go for it.
They don't understand at all!
Bring a valve amp home, tuck it away as much as possible and then play her favorite music. I think you'll win her over. Well, I'm going to try it at some point anyway...
I did sneak in some chord chorus 2 interconnects into the flat about 3 months ago but guilt go the better of me. Well, I told the missus when I decided I was going to resell them on ebay.
By the way, I have the p35 here with no power cable. Should I ring the shop and find out where the cable is, or do they not come as standard when buying second hand?ÿ
Igglebert, I was seriously considering your previous suggestion of the valve amp but decided, after a subliminal comment to the missus, that I better stick with the slightly cheaper option, and the matching fachia. Many thanks for the suggestion, though. Much appreciated and a thought for the future! The CD192 has two outputs and I can feel a teachers golden hello approaching in 18 months!
