Thanks Andrew - Think I asked that a while back but only just getting round to sorting correctly.
One final thing....My Davis10 is fantastic but really seems to lack in deep bass (explosions, rumbles in films etc) - Seems to lack quite alot.
Ive tried turning it up but doesnt help very much.
Anything else I can do to pump up the bass?
hi mate i hav a davis 50 its pretty much the same as yours only with the option of wireless rears. I have mine in my bedroom but i find the 2 rear surround speakers very quiet unless its pumped up to about 40+ is there any way of adjusting the rear speaker volume??
Have you set uo using the little mic that comes with the system - That helped my rears!
Its a subtle rear sound but should work well - Mine arent wireless though doubt that should make a difference ?
Andrew - Can you recommend a decent optical lead for not alot of money and also I think I need an optical switch as have sky hd hooked up to Davis already.
