Hi Thaiman
Hope you are well.
Having a dedicated ring main or spur with separate consumer unit for your system can be very worthwhile. I recommend that you go for 10mm Twin and Earth from a high quality consumer unit to a high quality unswitched socket.
You can then run a high performance power distribution block and shielded power cables from the unswitched wall socket to your system. This ensures the best power transfer and will minimise cable interactions behind your system. Having the dedicated ring main or spur should significantly reduce the amount of mains noise present but unfortunately it can still be conducted through the main inlet to your house. The level of conditioning required will depend upon the quality of the mains. Our research and testing has shown that a high quality conditioning filter will remove most noise (both differntial and common-mode); when the noise gets very significant (usually of common-mode type) where it is negatively affecting music reproduction then further conditioning (e.g., through isolation transformers) may be required.
Hope this helps!
Best regards,
Darren
