Ok guys some better news.
It looks like there is no issue with the speaker or amp. I think its due to the fact everything was plugged into a tacima mains block and maybe that was causing some interference.
I moved things about and reduced the hum by quite a bit, only a slight noise now, ever so slightly more than the right channel.
I moved the left speaker to the right channel and no hum.
I think it could be just the signal coming out of the mains on the left side of the room, becuase the right side is pretty silent.
there is a subwoofer on the left hand side near the speaker too dont know if that would cause anything? also i have a netwrok adaptor plugged into the wall on the left side also.
I think also i need to make sure everything is plugged directly into the wall rather than a mains block and also use decent mains cables? Im using various ones at the moment of differing quality.
finally the interconnects from my preamp to amps are not the best so i could maybe invest in some decent ones to keep the signal clean.
Im just happy i dont have to send the speakers back yet again!
