Dali Ikon 6 5.1
I'm so torn between this and an RS6 package!!!! My only problem is I can't wall mount the rears
Any one know if it is at all possible to stand mount the rears from the Dali Ikon Package?
Aeis:
Get the RS1 speakers as your rears - these are award winning bookshelf speakers from the RS range. Try your local Sevenoaks store and they will do a deal with you.
Aeis:
probably not, but the Ikon 1's or 2's would slot in nicely.
I have the 6 5.1 and you don't have to wall mount the rears. If you are wall mounting, then you literally put a single screw in the wall and hang of that, otherwise you can bookshelf mount them no problem. All you'd need is a little blue tak. They're not so narrow they won't stand up or might wobble. They're heavy and not that small at all. So quite a flexible speaker. The package is brilliant and a bargain at that price.
