dac or sound card? help please
i want better sound quality from my pc to stereo amp so would i be better with a good sound card or a dac?
links to ones i'm thinking of....
http://www.whathifi.com/review/arcam-rpac/specs
http://www.overclockers.co.uk/showproduct.php?prodid=SC-000-AS
thx. :grin:
Overdose
279
If soley using your Pc, I'd be tempted to lok for a mint used UA-25EX.
If you just want a DAC with no bells and whistles, just good sound, then have a look at the Epiphany E-DAC.
ifor
115
12
18,595
You might like to check this out, it's to be released next week.
http://www.gspaudio.co.uk/bitzie-usb-dac-external-soundcard.htm
Have a look around the GSP forum and you will learn a lot about its development and if you are interested you would be able to join the queue fo a two week homeloan.
kmlav
36
I use an rPac for headphones in the office using a Apple Mac running itunes with lossless files and the sound is great. Tried it a home on the main system with good results , good upgrade and good value.
hi thanks for replies. i have a cambridge audio azur 640 amp and mordaunt short aviano 1 speakers.
