Question DAC between TV and amp not recognized
Papistisk
Hello everyone!
Iam having difficulty setting up my speaker system to work with my smart TV(Q70R 2019).
I was told the best solution to getting sound to my speaker system was via HDMI arc through a DAC and then RCA connection to the amp.
This was the advice from a hifi store and they made it seem like it would "just work". Afcourse it didn't..
I bought the cheapest DAC, as I was under the impression it really didn't matter too much, and plugged everything in correctly. It does also recognize the hdmi input it just says that it is "unknown". If I try to apply it directly it will try and use it as a video input. Iam unable to see anywhere to tell that this is a speaker system that it should output sound to.
I afcourse tried some troubleshooting like turning everything off and unplugging but it's hard to get good results on Google.
Maybe someone here could have a fix for the current equipment or alternatively simply offer a different solution that will work!
Best regard
Emil
Hi!
It would help if we knew the brand of the DAC really
